Very long building acc. structure
I am experiencing very long building acc. structure since upgrading to 1.5, 1.4 didn`t have that problem. It happend in all projects with over 10m poly, so nothing special.
What could be causing that?
Thanks,
Hrvoje
Same problem… don’t know why… Any help?
I don’t see anything about this problem in this 10 pages topic…
thx kifo, i’ll try this 1.6 version
Hello
Have had the same problem with Corona 1.4. In my case it was connected with Windows updates.
Hm, I will try if Win update works it out.
Does installing 1.6 db fix this issue?
Hello hrvojezg00,
This morning i update my windows 7. I did all updates.
The problem is gone… i’m still with corona 1.5 hotfix 1
Best regards
Thanks micmac, Corona support is very slow these days.
Hi Hrvoje, have you contacted us about this recently? I can see a support ticket regarding similar issue submitted by you, but the last message is from 5 months ago. You are right, currently the replies may come a bit delayed, that’s because we received a lot of tickets and questions after the 1.5 release - which is actually good, because it indicates how much interest there is in Corona.
As to the issue itself - this is often very hard to diagnose. Could you provide us with a sample scene where this happens, or at least a good description of the scene and the problem itself? What exactly are you doing, and what is happening?
Hi Maru,
I will open a ticket for it. But generaly, I have weird Building acc. structure behaviour: when I start a new render it takes 2-5 min (20m poly project), upon render restart it take less then a minute, so its not constant. I can`t figure out whats wrong. Any ideas?
windows update… try
Win update made it work, thanks micmac!
