VERY simple but VERY important
As we all know when you work in this industry, you are often deprived of sleep, and therefore it is easy to make a stupid mistake… I just have.
When you render using the frame buffer and saving to a VRIMG file, it would be VERY nice if, like the max system, vray gave you a warning that you are about to overwrite a file if one already exists.
I just rendered out a 10 hour render, and then was setting up a new camera angle and doing a small test. I forgot to untick the save to file option and it imediately overwrote the file I had just completed. As a result of this silly mistake I will now miss the clients deadline.
So if you could put this little function in to help the sleep deprived that would be terrific.
Thanks.
ouch :?
Yeah, that happened to me as well. But in my case it was because i opened somebody´s else max file and didn´t check this particular output. The same goes to the split g buffer channels, the irradiance map file and the light cache one. It would be good to have warnings for these critical outputs.
maybe even a message if you ticked “don’t render final image”.
second this. I’m working on a project with lots of revisions, and this is biting me in the butt left and right.
Third it please!
…agreed!
…and here!
Admittedly I turn it off quite often since I’m an arrogant bastard but deadline, the render manager from frantic has this really nice feature called “sanity check” which checks to see if file names are correct, all maps are there and output file saving is turned on - not a direct equivalent but something along the same thought…
I sixth this!
seventh this !!! (is it a word?)
+1
happened to me also,
I dunno but I ate it
Yes, a warning anytime you are about to overwrite a file. (IM, LC, proxy, etc)
I ‘ninth’ this.
Tenth!!!
+1
(although I have worked around it by always rendering to a temp directory and moving files to “permanent” location after every render completes. That way I’ve got 2 versions on tap until I re-render as well.)
b
Agree too… Especially for previews..
Maybe there could be some automatic function that just adds a number if the file already exist… or an overwrite option, etc..
Also it would be nice if .exr are supported when choosing the render-to file browser.
