very strange DR
Hi All,
I have the latest daily build installed and 3ds max 2016. I have followed every example to get Dr to work.. backburner etc. My problem is that when I start DR the slave picks up and starts rendering, but its own individual VFB, does not sync with my master and when i stop my master it continues to render. I then press stop on the slave and it says it is gathering passes. It in now way syncs and is working as an independant render like backburner ?
Any suggestions ? I have reinstalled max and backburner and corona
First thing: which version of Corona are you using? The newest daily builds include a fix that was made specially to prevent cases like this (and more) so it should solve the problem. You can read more here: https://coronarenderer.freshdesk.com/support/solutions/articles/5000570015
If you do not wish to “risk” with daily builds, you will need to wait for v1.3 (release candidate should be here in a bout a week).
Hi Maru,
Thanks for the update. I had installed the daily build late last night, but the new one today seems to have fixed the issue.
