Vexus
I am trying to build some render passes for Corona using Vexus and having a few issues. I would like to clarify 2 things and potentially use this thread to feed back to the community solutions/further questions.
  1. Lightmix/Post process - I would like to have a different lightmix per camera - how do I call this function with maxscript? eg Cam01_Lightmix.conf & Cam01_Post.conf
  2. Where can I find a reference to all Corona code functions so I can put this node in myself - and any further nodes that do not exist in Vexus yet? (Im not the best with any code but Im willing to try) Currently Im referencing these two sites but Im hoping theres more information somewhere:
    Corona Doc | Corona Renderer
    https://coronarenderer.freshdesk.com/support/solutions/articles/5000501970-corona-maxscript-list-of-functions
thanks!
Is there a way from maxscript to call the .conf file into the lightmix?
Or even better - write from maxscript directly to the CShading_Lightselect 01 pass? I would like to call a different lightselect setup per Camera
This so far is my day of trying lol…
.AddRenderElement element
I am having trouble understanding how this simply works?
None of this below works… any push in the correct direction please?
CShading_Lightselect LS_Sun 0
-- Argument count error: reftarg create wanted 0, got 2
-- MAXScript callstack:
--	thread data: threadID:12056
--	[stack level: 0]
--	In top-level
CShading_Lightselect LS_Sun=0
-- No ""="" function for (Global:CShading_LightSelect Global:LS_Sun)
--	[stack level: 0]
--	In top-level
CoronaRenderer.CoronaFp.CShading_Lightselect LS_Sun=0
-- No ""="" function for ((prop CShading_LightSelect (prop CoronaFp Global:CoronaRenderer)) Global:LS_Sun)
--	[stack level: 0]
--	In top-level
CoronaRenderer.CShading_Lightselect LS_Sun=0
-- No ""="" function for ((prop CShading_LightSelect Global:CoronaRenderer) Global:LS_Sun)
--	[stack level: 0]
--	In top-level
Vexus - Initialization Success. Listening On Port: 7002
elementlist
undefined
-- Error occurred in anonymous codeblock; filename: ; position: 51; line: 1
-- Argument count error: AddRenderElement wanted 2, got 1
--	[stack level: 0]
--	In top-level
--	[stack level: 0]
--	In top-level
--	[stack level: 0]
--	In top-level
RendererClass.AddRenderElement CInfo_RenderStamp
-- Unknown property: "addrenderelement" in RendererClass
--	[stack level: 0]
--	In top-level
RendererClass.renderelements CInfo_RenderStamp
-- Unknown property: "renderElements" in RendererClass
--	[stack level: 0]
--	In top-level
maxOps.GetCurRenderElementMgr()
<MixinInterface:RenderElementMgr>
MixinInterface:AddRenderElement CInfo_RenderStamp
-- Syntax error: at keyword parameter, expected <factor>
--  In line: MixinInterface:A
MixinInterface:AddRenderElement CInfo_RenderStamp = true
MixinInterface:RenderElementMgr.AddRenderElement CInfo_RenderStamp
--  In line: MixinInterface:R
MixinInterface.RenderElementMgr.AddRenderElement CInfo_RenderStamp
-- Unknown property: "RenderElementMgr" in MixinInterface
--	[stack level: 0]
--	In top-level
-- MAXScript ** interrupted **
 Exception:
-- ** interrupted **
maxops.RenderElementMgr.AddRenderElement CInfo_RenderStamp
-- Unknown property: "RenderElementMgr" in <Interface:maxOps>
--	[stack level: 0]
--	In top-level
maxops.MixinInterface.RenderElementMgr.AddRenderElement CInfo_RenderStamp
-- Unknown property: "MixinInterface" in <Interface:maxOps>
--	[stack level: 0]
--	In top-level
 Exception:
maxops.MixinInterface:RenderElementMgr.AddRenderElement CInfo_RenderStamp
-- Syntax error: at keyword parameter, expected name
--  In line: maxops.MixinInterface:R
 Exception:
-- Argument count error: AddRenderElement wanted 2, got 5
--	[stack level: 0]
--	In top-level
 Exception:
RenderElementMgr.AddRenderElement.CInfo_RenderStamp
-- Unknown property: "CInfo_RenderStamp" in AddRenderElement()
--	[stack level: 0]
--	In top-level
 Exception:
RenderElementMgr.AddRenderElement CInfo_RenderStamp=true
-- No ""="" function for ((prop addrenderelement Global:RenderElementMgr) Global:CInfo_RenderStamp)
--	[stack level: 0]
--	In top-level
 Exception:
--	[stack level: 0]
--	In top-level
 Exception:
RenderElementMgr.AddRenderElement "CInfo_RenderStamp"
--	[stack level: 0]
--	In top-level
 Exception:
RenderElementMgr.AddRenderElement "CInfo_RenderStamp = true"
--	[stack level: 0]
--	In top-level
 Exception:
AddRenderElement()
 Exception:
RenderElementMgr.AddRenderElement.CoronaRenderer "CInfo_RenderStamp = true"
-- Unknown property: "CoronaRenderer" in AddRenderElement()
--	[stack level: 0]
--	In top-level
RenderElementMgr.AddRenderElement CoronaRenderer.CInfo_RenderStamp
--	[stack level: 0]
--	In top-level
 Exception:
RenderElementMgr.AddRenderElement CoronaRenderer CInfo_RenderStamp
-- Runtime error: Object does not implement this interface: RenderElementMgr
--	[stack level: 0]
--	In top-level
 Exception:
--	[stack level: 0]
--	In top-level
 Exception:
--	[stack level: 0]
--	In top-level
 Exception:
elementlist
undefined
RenderElementMgr.elementlist
-- Unknown property: "elementList" in RenderElementMgr
--	[stack level: 0]
--	In top-level
 Exception:
re.numrenderelements()
-- Unknown property: "NumRenderElements" in undefined
--	[stack level: 0]
--	In top-level
 Exception:
AddRenderElement()
 Exception:
RenderElementMgr.AddRenderElement(CInfo_RenderStamp)
--	[stack level: 0]
--	In top-level
 Exception:
 Exception:
MixInterface.RenderElementMgr.AddRenderElement CInfo_RenderStamp.element
-- Unknown property: "RenderElementMgr" in undefined
--	[stack level: 0]
--	In top-level
 Exception:
-- Argument count error: AddRenderElement wanted 2, got 3
--	[stack level: 0]
--	In top-level
 Exception:
MixInterface.AddRenderElement CInfo_RenderStamp.element
-- Unknown property: "addrenderelement" in undefined
--	[stack level: 0]
--	In top-level
 Exception:
MixinInterface:RenderElementMgr AddRenderElement CInfo_RenderStamp.element
 Exception:
maxOps.GetCurRenderElementMgr.AddRenderElement.CInfo_RenderStamp
-- Unknown property: "addrenderelement" in GetCurRenderElementMgr()
--	[stack level: 0]
--	In top-level
 Exception:
maxOps.GetCurRenderElementMgr.AddRenderElement CInfo_RenderStamp
--	[stack level: 0]
--	In top-level
 Exception:
maxOps.CoronaRenderer.CoronaFp.CInfo_RenderStamp
-- Unknown property: "CoronaRenderer" in <Interface:maxOps>
--	[stack level: 0]
--	In top-level
 Exception:
maxOps.GetCurRenderElementMgr AddRenderElement CInfo_RenderStamp
-- Argument count error: GetCurRenderElementMgr wanted 0, got 2
--	[stack level: 0]
--	In top-level
 Exception:
maxOps.GetCurRenderElementMgr.CoronaRenderer AddRenderElement CInfo_RenderStamp
-- Unknown property: "CoronaRenderer" in GetCurRenderElementMgr()
--	[stack level: 0]
--	In top-level
 Exception:
maxOps.CoronaRenderer.CoronaFp.AddRenderElement CInfo_RenderStamp
--	[stack level: 0]
--	In top-level
 Exception:
-- Unknown property: "addrenderelement" in <Interface:CoronaFp>
--	[stack level: 0]
--	In top-level
 Exception:
CoronaRenderer.CoronaFp AddRenderElement:CInfo_RenderStamp
-- Type error: Call needs function or class, got: <Interface:CoronaFp>
--	[stack level: 0]
--	In top-level
 Exception:
 Exception:
maxOps.GetCurRenderElementMgr.numrenderelements()
-- Unknown property: "NumRenderElements" in GetCurRenderElementMgr()
--	[stack level: 0]
--	In top-level
 Exception:
 Exception:
--	[stack level: 0]
--	In top-level
 Exception:
maxOps.GetCurRenderElementMgr help]
-- Argument count error: GetCurRenderElementMgr wanted 0, got 1
--	[stack level: 0]
--	In top-level
-- Syntax error: at ], expected <factor>
--  In line: maxOps.GetCurRenderElementMgr help]
\-- MAXScript ** interrupted **
 Exception:
oronaRenderer.CoronaFp.AddRenderElement maxOps.CInfo_RenderStamp
-- Unknown property: "CoronaFp" in undefined
--	[stack level: 0]
--	In top-level
 Exception:
CoronaRenderer.CoronaFp.AddRenderElement maxOps.CInfo_RenderStamp
--	[stack level: 0]
--	In top-level
 Exception:
CoronaRenderer.AddRenderElement maxOps.CInfo_RenderStamp
-- Unknown property: "addrenderelement" in Corona_1_5__hotfix_2
--	[stack level: 0]
--	In top-level
 Exception:
`<true><RenderElementMgr>.AddRenderElement <maxObject>CInfo_RenderStamp
-- Syntax error: at bad, expected <factor>
--  In line: `<
 Exception:
