VFB 2.0 and denoiser
So on vray 5 when I’m progresive rendering to test something denoiser will jump in and denoise. On vray Next I would just click RGB to get back to the normal not denoised layer, but with the vray 5 they both look the same. A bug?
You’ll need to untick ‘autoswitch to effects result’ in settings :slight_smile:
You can use the ‘eye’ icon in front of the denoiser layer to show/hide it:
Yavor
Oh, that one.
It does not stay hidden though…it switches back on all the time.
I resorted to making it 0 opacity while tweaking.
Sorry, I mean it does not stay off ‘unless’ I remember to turn off ‘autoswitch to effects result’, so they are linked, which is a bit cumbersome.
Should be all in one place ideally :slight_smile:
oh cool! Thanks guys, will use the visibility switch from now on.
