VFB 2.0 - Scroll through Passes Dropdown
Hey there,
Not sure if this is intended or not. In the old Corona VFB, I was able to use my mousewheel to easily scroll through the passes in the passes dropdown menu.
I found this quite handy and used it all the time, since my focus could stay on the image while scolling through passes.
In the new VFB this “feature” isn’t available anymore, plus the menu moved from top center to top right. So my eyes always have to move between the menu and the actual image wich is pretty tideous, especially on ultrawide screens.
Is there any way to get the old behaviour back?
Thank you!
Have a great day!
Moritz
If the VFB 2 in C4D is the same as in 3ds Max, then you have to click once on render elements dropdown before you can scroll through items with the mouse wheel. I agree with you that the old system was more convenient when you could scroll without additional click.
+1, bring back the old behavior.
The LUTs dropdown is working the same as before, so it should be possible.
Hey romullus,
Thanks for the tip. just tried this. I click to open the dropdown and then scrollwheel down. Unfortunatly the menu just closes :wink:
Oh, I Forgot to mention: I’m working on Win11, Corona 12 hf2 and Cinema 2025.0.2.
@John_Do You’re right. The LUT-Menu works the same as before.
Hi there,
Thank you for bringing this to our attention.
This is under investigation.
Kind regards.
For the Corona team:
(Report ID=CC4D-927)
