Probably a weird question, but is there any way to convert what is displayed in the VFB to 8-bit via a layer (and not via display correction)?
The reason I ask is that I have a set of LUTs that only seem to work on 8-bit images unfortunately and it’s a bit of a hassle to bring a render into PS to see the LUT’s effect…
There’s no way of doing that; you can view the pixel values in 8-bit though (rollout at the bottom, next to the pixel values). Mind if you send the LUT so we can troubleshoot?
I had hoped you’d chime in. I have tried (I think) every combination of settings to no avail.
It’s mimicing the RAW->JPG conversion that happens in camera on a fuji x100v (and once that is successful a GFX too).
I am making it specifically for the Vray vfb.
It’s been an extremely convoluted process thus far.
Despite this already being beyond me, this isn’t quite what I’m after. I don’t believe there’s any resources out there that are for what I’m trying to achieve.
Fuji has a bunch of film simulations and I’m attempting to replicate these. The film simulations are only applied in-camera as the raw is converted into a JPG meaning the results are only available in 8-bit.
I have taken series of photographs of colour charts and calculated the difference between these and reference values and have ended up with a LUT via several pieces of shitty software which don’t really allow any control over colour spaces or encoding.
They seem to work perfectly in photos in 8-bit, not not in a 32-bit color space or in the Vray vfb. Happy to share what I have with you in case you’re curious to try and solve my problem
If I have measured the difference between the refernce values specified by the manufacturer of the color chart. and the output from the camera, this should work (as it does in 8 bit in photoshop). I suppose I could try and make a profile that gets the VFB output to match my starting point… I fear that won’t work as the whole 32-bit → 8-bit mismatch is going to happen again.
it would be:
raw render >> curves adjustement (most likely, or just lut if fuji log does not reach above 13.5 float) to encode into correct log >> lut (that would consist of acescg to BT.2020 conversion and the “fuji film look”.
I’m attaching lut that would take you from acescg raw render to Fuji F-Log.
put GFX100_FLog_FGamut_to_WDR_BT.709_33grid_V.1.01.cub e on top.
this might be the default Fuji look. I guess.
is there any Fuji software supplied with the camera? it should let you use those film emulations on a single raw photo, maybe even output this to log encoded 12 bit file. would make things much easier.
So the software that comes with the camera is operated on a PC/MAC but the processing happens in-camera (while it’s plugged into your workstation). It’s a bit of a black box and the RAWs do not get the same treatment unfortunately. This is why I am trying to match these 8-bit jpegs that come out of the camera.
I have made a lot of progress in the last 24 hours and am very very close to getting what I wanted. The problem I had was that I was matching “corrected” colors in sRGB. I remade the color chart in max which gave me raw colors to match with which has largely solved my problem.
There’s still a lot of stuff to do with color spaces and display correction that I really have a hard time understanding which I’m sure would have gotten me there sooner and would help me close that last tiny 1% gap between what I want and what I get.
