When rendering through Backburner and max 8 i get a BMP -MEMORY ERROR. Here is the line in the backburner log. This message appears on all 32bit machines
2006/01/30 19:54:40 ERR Job testFW42_cut24_max8_fast_noGI01 (Autodesk 3ds Max 8.0) failed for render_04
2006/01/30 19:54:40 ERR Error message: BMP - Memory Error
I need a few layers so I use the VFB. The workstation is a 64bit system running x64 prof. max 8 sp1 with vray 1.47.03. and 4gig of ram on 4200+x2. the render slaves are all 32bit ranging from 3 - 3.6GHz and 2 gigs of ram. So the equipment is fairly decent i guess. The frames formats are png’s.
Is there anything else i need to post to solve this issue.
Following plugins are useed:
Texture Layers 2.0
Color Correct 3.0.3.6
eGz Materials 1.5
I think these are all that are used and distributed over the network.
Thx for any advice and help in Advance
Ralf
