My frame buffer window and autosave outputs are different.
If I use the frame buffer window to save an .exr (ive tested both 32bit & 16bit / RGB & RGBA). And the results are the same as the frame buffer window.
However the autosaved exr looks way off in terms of lighting or gamma, i’m not too sure whats wrong.
there was indeed some error after some rewriting. Fixed, hopefully ![]()
