I rendered a sequence of .vrimgs and would like to batch process them with a vfbl file afterwards. Unfortenately the lens effects appear only on a few frames after processing all files, even with create effects results channel on. Any ideas?
While batch processing everythings like fine by the way. Loading them in Chaos Player or converting them to exr and the lens effects are randomely gone
Hello @martin_hennrich ,
Can you please share more information about this issue? Does it always happen to the same images or it every time it affects different images? If it always happens with the same images, please try to increase the threshold value and see if that will help. If not, could you please share some of the images, used for your tests so we can have a look? Also, please share the exact versions of V-Ray, Cinema4D and your OS. Thank you.
it seems that the problem appears only in the effect results channel. When i use the vrimg2exr the denoise and glare channel are both fine but not the combined effects results layer. Or could this be a problem of the chaos player having trouble extracting the layer fast enough on playback? Its Cinema 2023.1.3 + V-Ray 6 for Cinema 4D, hotfix 3 (v6.00.04 from Feb 7 2023)
Would you mind sharing some test images so we can have a look at this issue? Thank you.
