Can you tell me which 3ds Max version you are using? If you are using Windows 7, have you tried with the Aero theme disabled (or enabled, opposite of whatever you normally have)? If you are using 3ds Max 2012, have you tried changing between Nitrous/DirectX viewport driver?
In any case, unfortunately I don’t think we can do a lot to fix this issue on our side, but it might be possible to find a configuration where it does not happen (or least happens less often).
