Here’s a new one for me:
After rendering, I tried to save the image out of the VFB but got this error any time I pressed (any of) the save buttons.
I couldn’t save the rendered image anyway I tried and - annoyingly! - had to close rhino and re-render.
It reads “file dialogue failed with error code ffff.”
Could you please try deleting the following file:
C:\Users\you\AppData\Roaming\Chaos Group\V-Ray 3.4 for Rhinoceros 5\FrameBufferState.fbs
Afterwards, please set a valid file path for your VFB history, and the issue should not occur again.
Also, what version of V-Ray you are using? I’m pretty curious. I believe we fixed what was causing that issue in the latest build.
Latest build. It only happened the once, a rhino restart fixed the problem. No idea what caused it.
It happened to me too several times, I always resolved by restarting rhino.
I could not reproduce the issue. Any steps that allows me to reproduce the error? What OS you are using. Also what version of Rhino. Be sure you guys are using 3.40.03 version of V-Ray for Rhino.
