VFB Composite ExtraTex RenderElement and Dirt : Black result
When i add the renderElement “extraTex” with a vrayDirt assigned, in the VFB composite layers, set to multiply…its just black. I saw in the 3dsmax forum, a solution where you need to add a rgb renderelement layer underneath to get it to work…which is does. Only problem is, that rgb layer destroys any changes made on other layers below.
How am i meant to comp the dirt layer?
Put the RGB layer below everything.
:slight_smile: thanks bud..i wish i had tried that :wink:
