VFB Corrections control
If I apply a colour correction with the VFB and save out the image via the VFB the correction is burned into the image. How ever if I pre determine the render output via 3ds Max the colour correction doesn’t get applied. This also happens with backburner. Is there a way to make it stay?
Do you still have the V-Ray VFB enabled, even though you are using the V-Ray frame buffer?
Ah I figured it out I think. If you use the render output in 3ds Max then the colour correction is not saved. How ever if you disable the 3ds Max render output and enable split render channels in the frame buffer and save the RGB it does save the colour correction. It doesn’t seem to work with 3ds Max output, is it supposed to?
Yes, it is supposed to work this way, should make a note about it in the docs.
OK, Thanks.
I have another issue. On the corrections control window I see an option to adjust exposure at the very top. If I move this slider nothing happens. There is also another slider below, which again does nothing. The oly settings that actually does anything is the curves correction. Am I missing something here?
You need to also enable the respective corrections from the bottom toolbar of the VFB window.
Yeah I just figured that one out. Doh! Thanks.
I cant seem to find any info on rendering intent and black point compensation. Is there a help file/reference for this?
You can read more about the rendering intent here: Introduction to the ICC profile format and I think we actually have to remove the black point compensation as it’s only used when printing.
Thanks again
