Well, basically as the title says. Right now there is an inconsistency between saving of Multichannel EXR, which does not have the corrections applied for the renderelements, and saving via seperate channels, which has the corrections applied to the render elements. See here for more info: Multichannel EXR: Corrections are not saved to render elements - V-Ray for 3ds Max :: Issues - Chaos Forum
Regards
Oliver
Hi, do you still need help with this one? There is a valid answer in the other thread. The VFB color corrections are applied only to the RGB as the name of the checker box implies.
My request is to add another checkbox or something else to be able to save corrections to the render elements as well when using Multichannel EXR, just like the option for separate render channels.
Thanks guys for implementing this!
