Currently working with vray 2.30.1 on two huge different scenes.
Ive got 32GB ram availalble and using 13GB while rendering.
On both scenes I am having the same stressful problem which is when i cancel rendering the VFB starts to freak out.
Appears, disappears, doesnt let me close, doesnt let me minimize or sometimes do anything at all.
Remember seing this problem some versions ago but can´t remember if there´s a solution.
I had that in 2012, too. It was amazingly annoying, to say the least! There wasn’t a fix, as far as I know. I just used the alt key, until it came back into focus.
Would it be possible to test it with the last official build ?
What about the difference between both windows accounts ? Are they both administrators ?
if its the 2012 its likely because:
1. you have aero enabled in windows
2. you have prograsive refinement enabled in max viewport
Get rid of both and you should be fine
