VFB History
It’s a hidden feature..so i don’t know if chaosgroup apprecciate problems reporting about hidden feature… but only for communicate that the clear button on VFB History doesn’t delete all images as older versions.
It deletes only some images…apparently in a random order.
Any other tested this??
Which operating system are you using?
windows XP 32bit 3gb Switch ON.
3dsmax 9 32bit
Vray 1.5 sp2
Same thing here on Max 9 64bit with sp2.
I’m on max 8 with SP1 and I’ve never had this problem. I’m getting everything upgraded to max 2009 and SP2 so I’ll test that out soon.
No problem here with Max 2009 + VRay 1.50 SP2 on Vista x64
