VFB icon scaling?
Is there an option I’m missing to change the size of the icons on the VFB window? They are very small on a 4k monitor and don’t change size with windows scaling. In fact on anything above 150% for me the text of the VFB actually becomes somewhat illegible.
Thanks for your time!
H
It is possible to change the scaling with the environmental variable VRAY_VFB_UI_SCALE. You could try setting a value of 2 or 3.
On a Windows machine, ‘Environmental Variables’ are created through the ‘Advanced system settings’ window.
On OSX it is not so user-friendly, so you could download the attached archive, unzip the file within and place it in /Library/LaunchAgents . Afterwards, restart the computer for the change to take effect.
VRAY_VFB_UI_SCALE.zip (550 Bytes)
That worked great, thank you very much!
VRAY_VFB_UI_SCALE is not listed. Should I add it to the list and input it’s value?
Doesn’t work for me. Always small icon. Please help me!
For information: I have Microsoft book 2 with windows 10 pro. i7 - 16Go RAM - Nvidia GeForce GTX 1060
Could you please tell what is your V-Ray’s full version number?
Is the environment variable set for the user account used when opening SketchUp?
What value have you used?
Kind regards,
Peter
This environment variable will affect only V-Ray 3 builds. I’m afraid there is no valid workaround for V-Ray versions 2.0 or older.
Kind regards,
Peter
Hi @Jcallanta
Kindly note that the .zip attached to this thread is for OSX.
Since you are on a Windows machine, it is only necessary to create a new ‘Environment Variable’ with a ‘Variable Name’ = VRAY_VFB_UI_SCALE and set the ‘Variable value’ to 2 or 3
