I get crashes quite regularly. All can be going well until, for example (this just happend), I add a vray distancetex into the mask slot of a vrayblendmtl. I then add a vraynoisetex into the distance slot and 3dsmax will crash after a short pause.This happens quite often. Is there a fix or is this just something that vray interactive cannot handle.
It seems that vray spews an error if I use a vraynoisetex in a distance slot without being interactive. Odd
3dsmax then crashes
Hi Steve, can you share your V-Ray/3ds Max versions together with crash dump files? Anything demonstrating the issue (screenshots/screen recordings) will be greatly appreciated, thanks!
@stevesideas , we’ve actually managed to reproduce this and is now logged in our internal bug-tracking system (ID number: VMAX-10349) for developer investigation. Thanks for the report!
