VFB IPR Next sp2: no more zoom control with CTRL+mouse click ?
Hi Chaos guys,
I’ve installed the last sp2 of Next for 3dsmax and it seems you changed some controls on VFB when IPR enabled.
I use a graphic pen and before last update I used the CTRL+mouse click (left or right) to zoom IN/OUT.
now CTRL enable the select objects command and I should use the mouse wheel to zoom.
Is there a way to come back to the old behaviour? Is ti possible to use another key combo like CTRL+SHIFT+mouse click?
Thanks in advance
I’m the one to blame here. I thought nobody uses those combos for zooming :slight_smile: I’ll make a note to bring them back with CTRL+SHIFT. Sorry :frowning:
Nice. Thank you very much!
More shortcuts are always welcome I suppose =D
it would be nice to have shortcut for render region too, just like the other renderers have (Corona ,Redshift?)
