VFB Layers Resetting
Hi all,
I am having an issue when i render. I add and change layers under the Display Corrections tab in the vfb. I re-render and the layer will either disappear on reset to default settings.
I am use RPManager which i feel is potentially interfering.
I am running 3dsmax as admin, and the history folder for the VFB has full control in the security settings.
Could someone point me to where i can remedy this?
Thanks in advance
JC
Does it happen without RPManager? Maybe it has its own settings and overrides the ones already set.
Hi Aleksandar,
Thanks for replying. It is a RPManager thing as the problem goes when not in use. I am guessing it is a permissions thing. When you add layers in the VFB where is the file being saved with this information?
Regrettably RPManager is a huge part of our pipeline and it is seemingly not being supported or developed any longer.
Thanks again for your help
Yh RP Manager is very ancient, I suggest looking at renderstacks or pulze or similar instead.
Isn’t it this setting as writed on RPmanager doc (see 7.25 bullet) ?
http://www.rpmanager.com/RPManager_Download_v7.htm
Tried this, seems to have no affect anymore.
:frowning:
This problem seems to have been fixed in new versions!
RPManager v7.8 for 3ds max 2013 - 2026
