VFB Lens Effects - Glare Mask
I have difficulties to use Glare Mask option smoothly … Object ID and Material ID still don’t seem to work ?
To summarize my tests:
- no Glare Mask → OK
- Intensity mask → OK
- Object ID mask → no more Glare
- Material ID mask → no more Glare
- Intensity + Object ID → same result as Intensity mask alone
- Intensity + Material ID → same result as Intensity mask alone
Anything I’m not doing right ?
Thanks for any help :slight_smile:
Regards.
There seems to be a problem with Intensity + other masks, but Object ID and Mtl ID should be working fine - can you send me an example scene with your issue at peter.matanov@chaosgroup.com ?
Good morning, Peter.
I’ll try to find some time to send you a stripped down version of the scene I tested v3.5 with. Thanks :slight_smile:
Hello Peter,
Email sent !
Regards.
