VFB makes mouse cursor disappear
Mouse cursor disappears if it’s inside the VFB window if I’m typing values anywhere in Max. This doesn’t seem to happen with the Rendered Frame Window.
Reproduction steps:
  1. Open VFB and Material editor
  2. Create a VrayMtl
  3. Highlight the value in any field. For example Glossiness
  4. Move the cursor inside the VFB window
  5. Type 0.6 (or any value really) while the cursor is still inside the VFB window
  6. Cursor disappears
BTW, doesn’t need to be Material Editor where you type values. It can be any place in Max that has an input field.
Max 2018.4 / Vray 4.02.04.00005
You can get the same thing with Scanline, so it’s not our fault (this time :slight_smile: ).
That’s strange. I tested this and I don’t have this happen with Scanline. It’s only in the VFB window where the cursor disappears and never appears again unless I move it outside of the window. With Scanline and Rendered Frame Window the cursor disappears when entering values but as soon as I move the mouse even one pixel the cursor reappears again. In VFB it doesn’t. Please check the video I captured - Unique Download Link | WeTransfer
