VFB not showing after loading render preset (BUILD 03.02.14)
Updating to this latest 03.02 build stops the corona VFB from showing when clicking render.
  • Resting setting has no effect.
  • Clicking on Show VFB in general settings has no effect.
  • Resetting the scene works though.
Attached in zip file is my settings I use for creating assets.
Is this a bug or will I just need to recreate the settings and save that .rps file. I also noticed before that some settings where not saving such as the render elements ‘elements active’ checkbox.
Thanks.
Corona - Blank Scene.zip (13.4 KB)
In your testing load all but common settings. It works okay.
Then load the common settings after and you will see the VFB will not show.
Rendered frame window setting seems to be the issue and not getting saved in .rps file from last version. Leastfrom one build to this one. Tested this with my current build and it works fine.
yes, “Rendered frame window” is the problem - it was unchecked in your settings.
Just to make you aware that the .rps file didn’t save that info.
I dont understand.
I opened max, loaded the preset - VFB checkbox got unchecked, I rendered, got no VFB, as expected
Sorry for confusing you.. the preset was saved with the checkbox ticked. I noticed it when I upgraded to the 03.02 daily build.
