VFB parenting issue
When I enable interactive render and I want to edit a material the VFB goes behind the Rhino windows. Very annoying issue.
Hi @javierrentas
Does this occur with every project and only in Interactive?
What happens if you reset the frame buffer state?
Please close the current sessions, navigate yourself to C:\Users\<USERNAME>\AppData\Roaming\Chaos Group\V-Ray for Rhinoceros and delete the FrameBufferState.fbs file. Open Rhino again and see if the issue is still there when you switch to the Asset Editor. Thanks!
I have this issue all the time at some point of the day. No idea why I get it. I will do what you recommended and let you know what I get.
Thanks!
Right, thanks for clarifying - do let us know if the suggested works.
