VFB problem when i switch the project.
Hi,guys,I found a problem that has not been solved.PLZ help.
Different C4D files with different exposure(EV),different Hightlight compreession in the render setting menu.
but when i switching and rendering the other project.
exposure(EV) and Hightlight compreession will change to the VFB’s parameter.I can only go to adjust VFB parameter bring it back to the previous file’s parameter.
This is no longer a problem. The post-processing settings should be saved in the scene. They are not immediately visible when you open the VFB (because there’s still the old rendering), but when you click render, they will change to the values that you saved.
