I have a problem saving EXR images from the VFB when I used region render. Since vray version 36003 it only saves the region instead of the whole image when I use the EXR format. It still works fine with other formats. Same problem with 36004.
It was still working with 36002.
This should be fixed in Beta 3. I can’t find it in the changelog either, it somehow slipped through and didn’t make it in the log, but it’s fixed and tested.
I can’t tell right at the moment if it’s in beta 2 as well (need to check tomorrow) - but I just double-checked the beta 3 builds and it’s working there.
We just released beta 3 today, so you should already be able to download the builds from our website.
The data window option determines what will be saved with the render. But we’ve also made another change where saving from the VFB directly will always save the whole image.
