These are some bugs that I could find related to Interactive Rendering:
1- The 2d pan/zoom on max viewport and the VFB doesn’t match. As soon as I “zoom in” on the viewport while interactive rendering is active, I see a different area of the scene on the VFB and the difference increases as I keep zooming in on the viewport.
2- When interactive rendering is running, every time I have a mouse click, the render reloads on the VFB. Even when I’m just passing through channels or layers on material editor (without change anything) it reloads the VFB. It looks like it is not restarting the rendering but it flashes.
3- Also when rendering a region area on the interactive and change a parameter on the menus or just click anywhere on the material editor, the whole render reloads, not only the region box. Similar to the problem above. Actually it looks like the same issue.
