VFB + Render image
Hi Every one,
I am new in using corona render. I started using it (corona 6 (hotfix 1)) few weeks ago and faced two main problem.
1- render outputs don’t look clear1 it always has noise even though i change some of setting in render setup!
2- VFB disappeared even when I press its button the max frame buffer is the one show up!
I don’t have time and I really need your help as soon as possible
thanks in advance
“1- render outputs don’t look clear1 it always has noise”
If it’s not clear, the resolution is probably too low. If it has noise, there’s not much you can do, but just need to let it render more hours. You need a strong CPU.. Or maybe you can read on Corona help website for some optimizations. But you shouldn’t change render settings as those have almost no impact on render times.
“2- VFB disappeared” - this one is not very clear. Maybe you can post some pictures for problem nr 1 and 2, so you’ll be able to get better help.
Open render setup > system tab > system settings and make sure that Corona VFB is chosen in VFB settings.
