I have a region selected in the VFB (not in Max Common tab), and for some reason VRay has started rendering the entire image even with the region enabled. I can see the region, and drag it around. The little region icon is lit up. Is there some other way that I could have turned off the region rendering in the VFB. This seem to be affecting multiple scene. I should try a brand new scene..
Oddly, rebooting the machine fixed it. That I don’t get. It’s probably unrelated. Most likely the last instance of Max to quit (and thus the one that wrote the prefs to disk last) didn’t have the issue, and that fixed it.
Thanks for the code snippet, will try that if I see the issue again.
So I was using the VFB Interactive Rendering while I had Enable Built-in Frame Buffer *disabled* in the VRay tab of the Render settings. This is useful since I render with the default frame buffer for best support from Deadline (handles paths more conveniently). Enabling this checkbox fixed the problem!
Hmm, great find. We are not yet sure how to handle this - warning/docs limitation/fix/etc. However, I did log it (internal bug-tracker id: VMAX-12898 ) for investigation.
