VFB Save button default path
Hey Devs!
Currently it seems the VFB’s save button defaults to the same path as the max file that you’re working on.
Would it be possible (or beneficial?) to use the current render output filepath instead?
I sometimes will disable “save render output” for test frames and still want to save out a test to the same location.
Cheers
But does not it already work like that? see video attached.
I think it may be the case if you change the path after opening max, but if you open a file where the output is already set then it seems to default to the location of the max file rather than the existing render output.
Could be something funny in my ENU causing it but if I get time I’ll try to test on a couple of different machines in our office.
