VFB : Save Region Render
Is it possible to save the active render region at the same time as saving the Layer Tree Preset ?
Should I submit a request on the Ideas Portal ?
Could you clarify? You want to save both the region and the whole image? Or you want to save the Region’s location in the preset?
The region’s location in the preset.
Sounds like a good idea if you ask me, or at least an option for it. Yes, write in the Ideas Portal.
I got interested in whether I could do it with MaxScript for the moment. Here’s what I came up with (attaching script): Basically, you choose an output folder, you set a region, and click Save. You browse to a folder, and the region’s coordinates will be saved in a .txt file. Afterwards, load such .txt files via the Load button.
SaveLoadRegionPresets.7z (1.32 KB)
Thanks for the script. I’ll give it a try.
I’ll also hurry up and post the idea on the portal. :slight_smile:
The script works very well with a rectangular region, but unless I am mistaken, it does not work with multiple regions.
For me, this is not a problem.
But perhaps some people would find it useful to have this option.
Thank you for this script, which is very helpful to me.
Yes, forgot to mention it works only for regular rectangular regions. Sorry. It won’t work for polygon regions because they are basically a masked rectangular region, so the coordinates will be from the rectangle. I’ll see if multiple regions can be supported.
EDIT: Same thing. Only the regular Rectangular region can work.
