That’s unfortunate. I’ll try loading my ICC first though. Thanks!
what is unfortunate is peddling on this forum information like:
ACEScg is the default colour management in 3ds Max 2025
or
Windows photo viewer uses Gamma 2.2
OCIO is the default colour management system in Max. VRay (since 2.0 I think) had ICC support (as a view lut) in VFB to compensate for this support missing from 3dsMax. ICC colour management system is still available in VRay alongside OCIO.
Photo app on Win respects ICC profile from Win settings.
I still work with Gamma workflow and try to switch to OCIO workflow. I am having the same issues as the author of this thread. When I try to save image from VFB to JPG or PNG I have a different gamma in saved file than what I have in VFB. If I copy image to clipboard and paste it to Photoshop or IrfanView, and save it to JPG/PNG than I have file with image what I have in VFB. Can someone explain how I suppose to save files from VFB to JPG directly, without shaman dances using other software, please?
screenshot shows that you are not saving ocio transform from VFB (checkbox).
any ICC profiles in Win/Photoshop? you need to bring them to VFB. how do you keep your display displaying correct colours?
if you are using default ocio config from max you might actually be better off using just VRay’s build in ocio support and leave max in legacy gamma.
Oh, how did I miss this?! Shame on me! Thank you, that was it. After extensive testing OCIO I have figured out that I would better stick to Gamma workflow to keep compatibility with previous projects.
If any of you could help me with this one I would be quite grateful:
please share your profiled (software/colorimeter does not matter) srgb display icc (icm) colour profiles - for testing purposes.
thanks.
Max bitmap saver doesn’t have an option to save with sRGB. It only has gamma control. If you use the new OCIO mode, you will have all kinds of output options.
