VFB Slowdown
Not sure what you guys have done to the VFB but it’s slow as hell in Corona 10, well it is for me anyway.
All I’m trying to do is delete tone mapping operators, it takes ages after right clicking for the ‘delete’ option to appear, then it takes ages for it to turn blue so you can actually click it. Then when you successfully click it, it appears to be pot luck as to whether it actually deletes or not.
It’s really really buggy, here’s a link to quick screen recording, this is realtime not slowed down or sped up.
It takes an age to respond to clicks, when it does respond sometimes it adds the item, sometimes it doesn’t, sometimes when you delete an item it leave a space in the UI - notice how the + option disappears to add another operator, the space then disappears if you hover over something else, sometimes the space gets filled with a duplicate - notice how the bloom and glare header appears twice, sometimes other elements of the UI disappear for a bit.
It’s currently unusable for me, this will add hours to my days.
Using 3ds Max 2024.1 and Corona 10 Official Release from today
I was not able to reproduce any kind of lag with Tonemapping.
Do you have other applications running in the background?
Getting the scene for which you experience the lag and test it will be better.
Do you experience the same lag with other scenes? Does it still happen when restarting 3ds Max (and the PC too, maybe)?
it’s the same for me regardless of scene, i’ll try a full restart later but nothing else was running (chrome maybe), just tested now on an empty scene and it’s the same. It works fine if you do the tonemapping from ther ender setup ‘edit tonemapping’ it’s just in the VFB for me
using an i9-7980XE with 128GB ram if that helps
Not experiencing anything similar here. 2024.1 for Max as well, on Win 11.
Ok so last night I spent a while cleaning up my PC, uninstalled unecessary programs, managed to clear about 200 GB of space on C Drive, cleaned registry, updated drivers etc etc. Rebooted the PC, opened Max, opened VFB in an empty scene with nothing else running in the background and it still happens just like in the video I shared.
That is really strange. What GPU do you have? Have you ever experiences similar thing in another software?
GPU isn’t great, it’s a relatively old 1050ti.
Nope I don’t experience this elsewhere, I’ve never experienced it in Corona until V10
and which exact Max version?
It will be great to specify the driver version for 1050ti as well.
See attached
Thanks.
The report is created to check on our side.
We will update you here in case of any news.
Hey,
I’ve been looking into this. Could you try installing the latest Nvidia drivers and see if that helps: Download The Latest Official NVIDIA Drivers
Please also run windows update and install any missing updates :smiley:
If it doesn’t help, I will continue to investigate this.
Cheers!
Rowan
Apologies, only just getting round to this. Do you recommend the Game Ready drivers or the Studio drivers?
Either should be fine. Only if you have problems with one, you can try the other.
Thanks,
Rowan
Problem persists with the latest drivers. If anything, it’s worse
That is strange, we tried this in our office with a range of systems and GPUs (including 1050ti and 650ti) and we cannot reproduce this at all.
I will ask someone from our support team to get back in contact with you and see how we can investigate this further.
Thanks,
Rowan
Just to give an update I think it could be an issue with my right-click menus in general, not strictly limited to Corona VFB.
I’m now having issues with simple right click commands in explorer. The VFB is still slightly unresponsive and laggy with left click operations.
For example, if I try to expand one of the rollouts, it doesn’t actually expand until I physically move my mouse again.
Hi, sorry, but we could not reproduce anything like that, and we are not getting any similar reports from other users. Of course this is not 100% certain, but it suggests there may be some problem with your hardware. For example: outdated BIOS/chipset driver, missing Windows Updates, some hardware malfunction. Also, unless I am mistaken, you have Unreal open in your taskbar. Are you performing some CPU- or GPU-heavy tasks with it? Maybe you are just doing too many things at a time? (again, no offense please if I am wrong, this is just a guess)
Found the problem.
maxstart.max
I removed my custom maxstart.max file and low and behold the VFB is super quick as I’d expect
If i put the maxstart.max file back again, the problem returns.
I’m going to try making a fresh maxstart file
