VFB still getting stuck in 3.4.02
VFB still gets stuck and i have to force minimize/maximize for it to work normally… Thought this issue had been fixed in a previous version?
Jup same here, 3 times out of 10 have this issue. Better than 10/10 but still.
Can you remind me what the issue was? Or just link to the previous thread?
Nevermind, I found it. Will take a look ASAP.
Hm, is this in 3ds Max 2017?
I have it in 2016 on 2 different computers. Vray 3.40.01. I’ve just updated to .02 will see if it improved.
No, it’s on 2015 SP3, it’s has been like this for the past 3-4 months or so, but i feel like it’s worse/more frequent since 3.4
Also happening on 2017 here.
Same recurrent problem here, with 3dsmax 2016, Win7.
Hi All,
This seems very randomly occurring and we have trouble reproducing it here, can you give more details on how it is reproducing? In particular:
    Is it happening after rendering;
    Can it happen with empty scene and default settings;
    Currently it is confirmed on Windows 7 only, do you get it on other versions;
    Can it happen if the VFB is not focused?
Alexander
Hello Alexander,
Here it’s always after rendering.
It doesn’t seem to happen with empty scene.
Sorry, but what do you mean by “if the VFB is not focused” ?
Thanks.
I’m on windows 10 max2015 sp3.
After rendering, both with region render and without. Both with bucket mode and progressive. I haven’t noticed this happening with RT GPU, but cannot confirm.
When it gets stuck, i cannot do anything in max, it seems the VFB becomes the only “clickable” thing apart from the taskbar, and i have to force minimize in the taskbar, if i start a new render it doesn’t maximize, so i have to manually click the taskbar again. Closing and re-opening seems to temporarily fix it, until it happens again.
I have this problem - though i’m not entirely convinced it’s the Vfb, as the rest of max seems to not respond unless I click onto something else (such as a web page, or another piece of software) and then back again. This could have just been a singular issue where max froze, but all the times it’s happened to me have been during (can’t pan in Vfb, but can zoom - anyone else got this?) and after rendering.
Literally after just posting this, I closed the Vfb after saving out an image and max closed instantly with it, with no save dialogue or anything. Very, very strange.
Had that last thing a few times too. No crash, no warning.
I had it happen once before, but I convinced myself that I must have pressed the wrong button - but this time, definitely not. Glad I’m not the only one.
Hm, i’ve also had some random crashes recently some with warning, others without warning, and both cases while rendering with Vray… Thought it was some plugin or something on my scene, but might be the VFB.
It’s somewhat unlikely that it’s the VFB… it would be best if you report those separately.
Vladop
About the VFB freezing issue again - are you guys starting the render from the VFB “render” button, or from somewhere else? There is one possible issue I can see if the render is started from the VFB button…
90% of the time i click 3dsmax’s default teapot button to render. Also most of the time this issue happens when i use VFB’s region render. When it freezes, the region render draw is unlocked and it just follows the mouse, i cannot lock it, so i have to press a windows taskbar for it to unfreeze.
Ok, thanks - that’s very useful information :slight_smile: Is this during rendering, or before you even get to render? In any case, will take a look through the region drawing code to see if there’s a missing mouse release somewhere.
