VFB to modify rendered sequence
As title suggests, is this possible? An example would be if I use VFB to lower the highlight burn. Apparently people who do compositing at my company are not able to easily replicate that, so if the sequence is already rendered and I need to lower the highlight burn for the sequence for whatever reason. Am I able to load the sequence to VFB and have it modified in batches?
Alternatively, is there a way to perfectly replicate the reduction of highlight burn outside of VFB in compositing?
Thanks for the response.
As I am googling further, I discovered the ability to save LUT as cube and apply in post process. That might work for my needs.
In addition to that - in V-Ray 5 Update 2 we’ve added an option for batch image processing in the File menu of the VFB.
Yavor
Ah ok, I’m at update 1.2. I guess we need to update it soon once the project finishes.
