VFB Vray 5 update 1 stack
Just install new updated, and found issue with VFB that appear always over my other applications. See screenshot
Also, when I hit the render and go to another program, Vray still attention and open 3ds max window
Never happened to me. Is this always happening? Maybe Max glitched or something, have you tried restarting it?
yes, I tried open new 3ds max, and just open VFB, same issues
BTW, How to make Cryptomatte that work with Multi/Sub-object materials? I didn’t find any option to make it work
Also I found that with new progressive Caustica on all materials became more darker and have diffrent look. Please see screenshot. A without any coustic. B with progressive caustic
Try assigning different Mtl IDs for the materials in the multi-sub.
For the caustics issue I need a scene to check your setup.
Ok. Please check the link for the scene. Render_01 is with caustic, render_02 without
https://drive.google.com/file/d/1mkag0cxw37Z5ODCzWr3YFkrBhkOpLSmz/view?usp=sharing
Any update on this issues? I just installed update and problem are still with stacked VFB. Not cheked yet issues with caustic
I use Vray Plane Light. But problem with caustic not very high priority for me as the problem with VFB that really makes me mad
@_Lele @vlado
may be you can have a look on this bug with VFB that pined on top over all programs?
Anyone can report this bug with VFB “always on top”? Or how I can solve this problem?
I’ve just installed 5.1 and I have the VFB alway in front - thought it was a ‘feature’?
Problem still no solved… :frowning:
Because nobody reproduced it here in the office. I’ll ask someone from support to arrange a remote session on your machine.
@Mikhalenko can we arrange a remote session to troubleshoot this further ? If yes, then please cerate a ticket in our system from our web site contact form https://www.chaosgroup.com/help/contact/support/general
mentioning this forum thread and we will continue the communication from there.
Great :slight_smile: Because it’s appear only with this update that very strange
with great help of @tashko.zashev we found that you need set environment variable for the VFB : VRAY_VFB_ALWAYS_ON_TOP with value 2
@Mikhalenko mind that this workaround is needed only when there is such issue(for now). The complains so far are literally only from this thread.
