in the past there has been a postage stamp in VFB, is there something with Vray5, too?
I need always to know, which frame of a sequence was rendered.
Also the picture information (available for saved pictures in the history by right button click) which has a vast list, writes only 0000 as current frame number, which is not true.
What you need to do is to click on that line and then click on ‘Insert Variable’…that puts that entry on to the stamp, so the same process for each data that you need added.
I was only testing once GPU, I’m normally always using CPU. But I’m sure it‘s the same with standard CPU rendering.
But I will check today and post in the issues section.
