I am running Vray for Sketchup 5.20.06 on an iMac (2020) with macOS 12.3 and also on my MacBook Pro - although the issues I describe have been present on previous versions of SU / Vray
I am not sure if what I describe below is ‘expected’ behaviour and maybe I am using the software in the wrong way, or it is something that could be improved…
- When a render completes, if I minimise the VFB window to get it out of the way (so I can maybe tweak my model), the Sketchup model window is minimised with it
- When I restore the SU window (Sketchup menu > Window > Select model), the VFB returns with it, it is still in the way but now none of the VFB window controls (close/minimise/maximise) work at all
- If I click on the VFB control in the Asset Editor, the VFB bounces off screen and returns, and I can now close it (minimising will affect SU window as beforel)
- If I use my iMac with a dual screen set up I don’t seem to be able to run the VFB on the second monitor, if I drag it there it will disappear completely. I can start/stop renders, click the VFB control in the asset editor window, select the VFB window in the Sketchup>Window menu, but nothing will get the VFB back unless I restart SU. (I can however keep the asset editor on the second screen…)
Am I not working the same way everyone else does, as this all seems a bit annoying to me!
Lastly is there any way to set the preferred file format for saving renders? It always reverts to PNG and I prefer EXR.
thanks
