VFB window no interactive render !!
Interactive render in the VFB monitor is not possible. When I press start the image will be rendered once but will not be re-rendered if I change something in the scene. But in viewport render it works ??? It used to work in the VFB window too. C4D R19 OSX, Corona Render 5 . Thanks in advance
You need to click & hold on that render button in the VFB. That’ll trigger a dropdown menu where you can select the IR option. :smiley:
