The VFB goes unresponsive when using GPU; it doesn’t update. I can’t even zoom. I can move the VFB around the screen, but that is about it. Canceling or pausing doesn’t work either.
You can under performance tab / change from cuda / rtx / denoiser. Add low priority
Although i havent tested if it works
I just recorded my screen. I’ll try what you say.
what performance tab are you refering too? EDIT: Found it.
