VFB2 further improvements - your help needed!
Almost all my wishes are already mentioned, so I will just vote for them to help rising the priority : ))
1- Sharpening / Blur
2- Post Vignetting
3-Absolute or override mode for the light mixer so we can ignore the current colors and add our own colors. I know this one would be tricky with textured lights but I can live with supporting solid colored lights only .
4-Access for VFB shortcuts. some of them are really annoying like Shift+Q that will make a comparison instead of rendering even with “Keyboard shortcut override” is off.
5-custom white balance color and (inverse) color picker option would be great.
Sharpening and Camera Raw in PS. Sometimes for saturate/brightness/hue but only for some colors in Camera Raw. Works great. And sometime just cloning repairing some parts. And sometimes add vignette in post.
To me it’s just camera raw abilities, especially “clarity” like function.
Possibility to add light materials to the Light Mix? :slight_smile:
It’s really simple actually.
Give me PS in VFB.
We are very far from the idea of fully replacing professional post processing softwares. This is why I’m asking for most used functions, so we can only implement the essentials.
Bring back Frame Stamps.
We don’t use VFB for much more than previews and LightMix, and the occasional Lens Effects (saved to separate channel). So for us it is the little productivity things rather than duplication of compositing software, which we do in, well… compositing software.
Frame Stamps would be very helpful indeed. We need to burn in the render node name, scenename, render time, peak memory usage, etc.
I’d love to have the BG image support image sequences so that the BG image is updated depending on what frame is rendered.
It would be great if the saved images in the history saved entire presets for the renderer, and we could then re-load the settings from a previous render. In a perfect world we would be presented with a dialog where we could choose to load specific settings. For instance, we could load the Light Cache settings from a previous render without changing the Sample settings, etc.
Perhaps the history could also save the light settings as a way of sort of reverting LightMix changes. In a perfect world we could load the settings for each light independently to, for instance, revert Light3 alone.
I was joking :stuck_out_tongue:
Sharpening is a must. HSL sliders from CR PS too.
I know that you are joking but there might people reading this thread that should know our general intentions :slight_smile:
Frame Stamps are coming.
“Load V-Ray settings” and “Compare V-Ray settings” are already in the builds and should work as before (right click on an image from History). Partial loading of particular settings might be a little too much :slight_smile:
This can technically already be achieved with the help of the v-ray presets.
Those allow for partial loading and saving of sections of render settings.
A bit more laborious, but quite doable.
That was along the lines of what I was thinking.
Also, it would nice to have in a pop up for each saved history image the Max file name and date and time saved.
Thanks for asking the users.
1. It would be very helpful to select several regions at once. Like in Corona. I know it can be done with a mask, but solving it directly in the VFB is much more handy.
2. Add a custom color option to White Balance / previously mentioned
3. Lightmix temperature / previously mentioned
“Masking is coming in Update 1.” THANK YOU! it will be awesome!!!
