VFB2 Lens Effects & Denoiser Layer Visibility - IPR scene changes
Are these layers supposed to automatically come back on after a change has been made in scene while working in IPR? (occurs with both cpu and gpu)
Example:
http://wanderplay.com/stuff/2020-10-02\_09-13-50.mp4
The video won’t play for some reason but I think I know what you mean. There is a setting for that actually :
Historically it controlled if the old frame buffer should switch to showing the effectsResult channel automatically when it is calculated. In the new frame buffer the denoiser and lens effects layer automatically turn back on when they are ready when the option is ON. If you don’t like that behavior - you can turn the “Autoswitch to effectsResult” Off.
Yavor
Thank you Yavor, that’s exactly what I was looking for. Cheers
