VfR4 at multi task Rhino
some times I open a new Rhino task and can’t open the VfR UI. The UI is empty.
-Micha
Hi @Micha
Could you please provide a step-by-step description how the issue is reproduced? Is a specific project loaded and then you open a new Rhino file from the menu or Rhino’s application icon?
Additionally, could you please advise what GPU model you are using and its drivers version?
Hi @georgi.georgiev
today I got my new GTX2080ti and so I installed the current driver - I can’t repeat the issue, but if I see it again, than I will look for a way to repeat it.
