VfR5 - previous used GPU mode set to CPU mode
if I open a scene from VfR4 which was be used in GPU mode (f.ex. 60 subdivs), than it is opened in CPU mode at VfR5. If I switch to GPU than my original max subdivs are doubled (120).
Interesting,
I’ll try to replicate that here.
We did update some of the backend logic when changing engines and managing quality settings and it’s possible that we’ve missed something.
I hope that everything works as expected after you save the scene in V5.
Konstantin
It seems that both the render engine and the mode are lost when Next scenes are loaded in V5.
The issue will be resolved with very high priority and a fix should make it in the first hotfix we put out.
Logged as - WEBUI-5667
Please note that after saving the scene in 5, the issue will not persist (only the initial state of Next scenes is affected).
Thank you for reporting this!
Konstantin
