Having strange problems with vsf. Running XP SP2. Ran vray on both sketchup 7 and 8. Both give same results. Clicking save on render output window brings up save dialog which acts normal but then no file is saved. Tried various image formats. Then when I set a save destination in the output tab of vray options and then hit render, then i get the message : “we have encountered error(s) while trying to render. Please check rhe error log for details” Where is the error log on this version of vray? Also had an odd occurrence when running vray on su8. The output window would freeze the whole machine if I clicked anything on the afore mentioned window, until I hit ctrl+alt+del one or twice which unfroze the system.
Any prompt help will be appreciated
