VFSU 1.48.89 AND rhino 1.05.30 installed on same pc
Is it possible to install both on the same pc? I read that they use the same folders/filenames, is there any workarounds to do this?
Started learning rhino and would like to install the 30 day trial out to check my models out :slight_smile: because if i import the models to sketchup, they lose detail!
Re: VFSU 1.48.89 AND rhino 1.05.30 installed on same pc
I’ve got VfSU 1.48 and 1.05 (both SketchUp) installed on the same machine.
I see, but i wondered whether installing rhino version now would overwrite some sketchup 1.48.89 files and break it?
also, how do you pick which version sketchup uses?
