I was doing some rendering yesterday, and it was pumping out renderings beautifully. I also rendered out an animation, it rendered 300 frames. The 4090 (installed directly below my 2080) was at about 66 degrees, BUT my 2080 got up to 98 degrees. Pretty sure that is hotter than I want it to get. What is a good solution to this? These cards are next to each other with maybe 1/2" between them.
If the case allows it, you could add a fan (maybe 120mm) to the side of the GPUs, feeding some fresh air into the 2080. Some cases have such fan slots on the side panel. Otherwise you could zip-tie it or something like that.
The other thing is to use an overclocking tool to underclock and/or undervolt the 2080, though if all the heat comes from the 4090 (in your example you were rendering with the 4090 and the 2080 was not very busy, right?) this may not help much.
Yes, I am rendering with the 4090, monitors are plugged into the 2080.
Could you post a link to your motherboard model? Which slots are you using? From what you said earlier it sounds like 2080 is in the first 16x slot and the 4090 is in the 8x slot and there is a free 4x slot at the bottom. You could try moving the 4090 to the top slot and the 2080 to the bottom 4x slot, with the monitor still attached to it. This will increase the spacing though the 4090 will get a bit warmer. A side fan could still help.
Yes, you are exactly right. 2080 is in top x16 slot and 4090 is in second x8 slot. I do have a x4 slot at the bottom of board. I am pretty sure I have a couple extra 120mm fans in my “computer box” will check.
- Mainboard: X570 Aorus Ultra
- CPU: AMD Ryzen 9 - 16 core
- Memory: 64GB DDR4
- Video Card: Nvidia Ge-Force RTX 2080-Super 8GB (plugged into top slot PCIEX16)
- Video Card: Nvidia Ge-Force RTX 4090 24GB (plugged into second slot PCIEX8)
- Windows 11
- 3ds Max 2025
- V-Ray 6 update 2.1
Hm, looking at this bottom slot, it’s very close to the end of the board. If you’re using the cable headers there it may not be possible to fit a GPU over them. Or if the case is not tall enough. Anyway, it was just an idea.
If you try swapping the cards, you may have to change the “Initial Display Output” option in BIOS. I found it on page 32 of the manual.
So, is this the better option vs putting 4090 on top and 2080 to bottom? My 4090 currently does cover up those lower cable headers on board but it clears most of them. One it was pulling on badly enough that I disconnected it because I was afraid it might break off. It runs my USB 3 plugs on top of my case. But I have a couple of usb 3 compatible hubs I can plug into back of case to make up for the loss of those.
How much warmer would the 4090 run? It was only at 66 under full load, so I think I have some room for temp increase as long as it isnt crazy high like my 2080 was.
Ideally both cards should have some space below them to “breathe” cooler air (even better with a side fan). For the bottom slot this means you need sufficient space below the lower edge of the motherboard before you hit the bottom of the case or the power supply. The priority for better cooled position should be for the 4090, though you probably also want to avoid putting it in the slower 4x slot (I’m speculating - maybe 4x is fine for rendering). You’ll have to experiment.
Are you using your 2080 for rendering with your 4090?
I see no other reason the 2080 would get this hot
I wouldn’t worry about the 4090 temperature in your setup, even in the topmost slot. The 4090 has a bigger cooler and doesn’t get hot in rendering
x4 Gen 4 should be fine for rendering, I have a 4090 on a very similar setup myself
I just have the 4090 set for rendering device and the 2080 is un checked in Vantage. My assumption was the heat was coming up off the 4090 (heat rises) and into the 2080. The 4090 was only at 66 degrees under full load rendering the 300 frames. I still currently have the 2080 in top and 4090 in second. Got busy over weekend and didn’t switch them. I don’t render animations very often, but when I do I would like to not have to worry about burning out my old card. The rendering end of Vantage is fairly impressive I must say. Im not sure if I can physically put the 4090 or the 2080 for that matter in bottom slot. Problem is my power supply is at the bottom of case.
Check the temperature of the 2080 again at idle and under load, use GPU-Z to monitor the hotspot and other sensors
Kinda hard for me to believe it runs at 100 degrees C, you need to make sure it is the case
Moving your 4090 to the top slot and the 2080 to the lowermost slot should work as well as last option
Best,
Muhammed
2080 at 4% load is 65.9 degrees, 2080 at 89% load is 79.9 degrees. 4090 at 0% load is 37.4 degrees, 4090 at 99% load is 55.3 degrees. The only way I know how to put the 2080 under actual load is to temporarily let vantage use it. I may have a real problem here. I think that vantage is using both cards to render. Every time I go into “render devices” the "automatically select is always on and neither card is selected. If I turn auto select off and select my 4090 it says I have to restart, and when I restart it puts the settings right back the way they were. I just checked a render with gpu-z and BOTH card loads are being cranked up, so I think its using both.
Yup, that is what I thought. If the 2080 is not used for rendering it will not hit 100 degrees
@npg Any thoughts why Vantage uses both GPUs, disregarding the device selector?
You can check if both devices are being used in the log (Help->Open debug log), somewhere near the beginning it says “using device #”. It also shows it in the status bar.
I was able to reproduce this - it is a bug introduced in 2.5.2. You can either use 2.5.1 or create a shortcut that runs “vantage.exe -d 1” or whatever the index of the 4090 is in the log.
According to the log, yes it say it is using both devices. I hope they fix this bug. What I dont like about the previous version is the bug that was in the geolocation spinners. But I like this bug even less. I will try to add that switch to my shortcut and see if that works. It is also listing both devices at bottom right of Vantage. Although the memory count that it shows appears to be the memory from the 4090. Thanks as always.
Yes, the primary device’s memory usage is shown because it uses a bit more than the secondary device. Though the color coding ignores the fact that the second GPU has less memory in this case (in most dual setups the memory size is the same).
The bug will be fixed in the next update.
I guess I dont remember how to add a switch to a shortcut. I have tried adding and doing new shortcut and it wont accept it no matter what I type in. I used to know how to do this, but apparently I forgot.
I am really trying to figure out why I am even running both cards. When I load a scene into Vantage I still have about 20g free vram. The 2080 is at around 5 gpu load normally since it isnt doing much. Is it really advantageous to even run 2 cards given my specs? Eventually (for work) I may have to bring in sites with a lot of civil topography and I am guessing thats going to take more vram probably, but not sure if I will ever cap out my ~20g that I have free now. Thoughts?
Ok, so due to the 2080 overheating I ended up taking it out. I have been just running with the 4090 and things have worked just fine. I know that its just a matter of time though until I really need the 4090 to be a dedicated card, so I ordered a second 4090. I should have it end of next week. Have a couple questions. If I put the new card in the second slot (other one is in top slot) will things still be ok with them being right next to each other? And if I use that config, which slot (top or second) should I use for the monitors? I noticed during rendering the 4090 barely heats up. Certainly nowhere near “hot”. Like always, your help is always greatly appretiated.
