Tried to append my computer’s specs in the signature. I wrote the information in the Status input of the About Section in my User profile. Can someone please tell me the proper way.
For now: Intel Core i7 6700K @ 4.00 GHz | Gigabyte Z170XP-SLI-CF | 32 GB HyperX Fury 2666 MHZ DDR4 XMP | NVidia Quadro K4200
I am posting this to figure out what the best video card within my budget is and clarify some uncertainties with overall GPU use within V-Ray, but other 3D applications as well.
For V-Ray renders I use 3DS Max 2020. I am also a Mudbox user and have become quite active with Autodesk Inventor for 3-4 years now. So my first question revolves around the Quadro line of video cards.
My GPU is a Quadro K4200. I had read that Quadro cards were best for CAD applications. Is this entirely accurate? Please share any details or resources to read.
Following the intro tutorials while using V-Ray Next 3.2 (also signed up for the Beta version) I got the warning [VUtils::setDenoisingDeviceContext] No suitable CUDA devices available for denoising. Compute capability >= 5.0 is required.
At the present moment believe 5.2 Compute Capability is needed, right? Went to: CUDA GPU Compute Capability | NVIDIA Developer and looked through what cards fit those requirements. Then scouted video cards on eBay to see what would fall into my budget.
As of now can only spend between $300-500, but in a month or so might be able to afford in the $600-900 range (or hopefully, maybe, more…:o)) Might even be worth getting a card asap, and then upgrading to another one after a few months..?
As mentioned previously am not certain if getting another Quadro card is the best idea, as I have read that using a Quadro for display and pairing with another type for rendering would be an ideal setup. Could someone elaborate what would be best?
So in short hoping to figure out what are some of the best options? In the $300-500 range found:
Quadro M6000 & Quadro P2200
In the $600-900: Quadro P4000 & Quadro RTX4000
How important will a higher Compute Compatibility than 5.2 be? Meaning in the coming 2-6 months will 6.1 or higher be the requirement?
Thanks, have a spectacular day.
