Video Editor Command Greyed out?
I’m trying to create a walkthrough video, but the Video button is greyed out in the toolbar. A message appears when I hover over it that says “Unavailable while orthographic projection is in use” but when I go to settings, my projection is set to perspective. However, that button is also greyed out and will not allow me to change that either.
Does anyone know what this could be caused by??
Hi @Cristinall8 and welcome to our Forum.
Right away if this behavior still persists, perhaps you might’ve enabled “Synchronize Views” via the Enscape menu in Revit? If so, kindly try deactivating that functionality which should in turn then allow you to change your perspective again and make use of the video editor.
Let me know if trying the above does not resolve this.
